Date/Time: Wed, 25 Nov 2026 21:36:01 +0000
Volume Profile Configurations
View Count: 480
| [2025-12-03 12:29:04] |
| Cileron - Posts: 52 |
Is there a way to have multiple tool configurations with the draw volume profile tool that I switch between without having to manually go to the settings and making the desired changes? Normally with all the other tools I use I can just switch between the TC1, TC2, etc. and it would automatically change the properties of the tool but it doesn't seem to work that way with the volume profile, but I want to have to instances of it if possible.
Date Time Of Last Edit: 2025-12-03 12:39:19
| [2025-12-03 15:11:01] |
The Draw Volume Profile allows for the same ability to have different configurations, just like the other drawing tools. Refer to the following: Chart Drawing Tools: Using Multiple Drawing Tool Configurations Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
