Date/Time: Sat, 18 May 2024 07:58:28 +0000
Sierra Menu buttons greyed out...
View Count: 857
[2014-10-17 00:30:22] |
User19546 - Posts: 7 |
Why do some Toolbar buttons "grey out"? What is the cure? Date Time Of Last Edit: 2014-10-17 01:10:30
Menu problems.JPG / V - Attached On 2014-10-17 00:31:32 UTC - Size: 306.64 KB - 345 views |
[2014-10-21 00:31:04] |
We are aware of this problem. We are looking for a proper permanent solution but that will take some time before it is done. It is not a common occurrence but we do have a few reports of the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-21 00:31:19
