Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
Number Bars Calculated Value Question
View Count: 391
[2025-11-30 16:07:16]
Cileron - Posts: 52
is there a way to how a certain candle’s delta ranks with other candles in that session? I would like to know if I'm looking at the highest delta candle of the day or one of the lowest to help my decision making for classifying weak or strong delta
[2025-12-01 04:12:59]
You could possibly use the Relative Volume study:
Relative Volume
And based it on this study:
Ask/Bid Volume Difference Bars
[2025-12-01 17:30:11]
You can do this with the Numbers Bars Calculated Values study. Use the "Color Background Based on Value Percentage" option and set the "Determine the Maximum/Minimum Values for Background From" to "Daily Data".
If you then set your "Percent Compare Threshold" such that the third value is a number like "0.99" then the "Range 3 Up Color" and "Range 3 Down Color" will show you where the highest and lowest delta occurred for each day. You can set those colors to something that will stand out to make them easier to find.
Refer to the Inputs at the following link:
Numbers Bars: Numbers Bars Calculated Values Input Descriptions
