Date/Time: Wed, 25 Nov 2026 21:35:48 +0000
plot bid ask spread
View Count: 392
| [2025-11-29 20:29:28] |
| doctor10 - Posts: 88 |
How do we plot the difference between the bid and ask prices? thanks |
| [2025-12-01 16:49:25] |
It depends on exactly what you want. To start with, refer to the following and the item below it: Chart Menu: Show Bid and Ask Lines (Chart menu) And then there is the following study: Bid & Ask Prices If you want to get the actual spread itself as a single value, then you can use the Arithmetic studies to calculate the difference between the two subgraphs from the above study. Refer to the following: Using the Basic Arithmetic Studies You can then display the most recent value (or some offset value) using this study: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
