Date/Time: Thu, 26 Nov 2026 03:41:26 +0000
Detached window menu disappeared
View Count: 681
[2025-11-27 05:58:29]
User556806 - Posts: 28
Hi SC team,
When the chart detaches, its menu disappears (Edit/Chart/Analysis....). How can I restore it?
Thanks a lot!
imageDetached.JPG / V - Attached On 2025-11-27 05:57:42 UTC - Size: 19.33 KB - 171 views
[2025-11-27 06:17:04]
Sierra_Chart Engineering - Posts: 25489
Right click on the header line of the chart, not the title bar but the header line, just below the title bar, and then select "Show Menu".
Date Time Of Last Edit: 2025-11-27 06:17:20
[2026-03-19 18:31:25]
User708340 - Posts: 21
Hi Sierra
My menu disappears (Edit/Chart/Analysis....) too after detachment.
Where is the header line of the chart?
[2026-03-19 19:36:16]
If you have a detached chart with the Title Bar not showing, then select "Chart >> Show Title Bar" to put a checkmark next to that item and have the Title Bar displayed again.
If the menu itself is not showing, then follow the instructions at the following link to get it back:
Chart Menu: Show Menu (Chart menu)
[2026-03-20 16:36:45]
User750920 - Posts: 297
Can you post a picture of the header line location.
[2026-03-20 20:03:32]
This will be at the very top of the chart as shown here:
Working With Charts: Region Data Line / Chart Header
