Date/Time: Tue, 17 Nov 2026 18:09:08 +0000
missing historical data on Sierra Chart.
View Count: 971
| [2025-11-26 23:28:40] |
| User673306 - Posts: 1 |
Hello, I have an issue with missing historical data on Sierra Chart. Symbol: NQZ25_FUT_CME (and ESZ25_FUT_CME) Problem: 1. In 1-Minute and 1-Hour charts, data stops at 2025-10-28. I cannot load any intraday data before that date. 2. In the Daily chart, data only goes back to May 2025. No older daily history is available. My current settings: • Intraday Data Limiting: “Use Number of Days To Load” • Days To Load: 4380 • Symbol: NQZ25_FUT_CME • Service: Teton CME Routing • Data feeds: Denali Real-Time + Delayed Exchange Data Feed enabled • I pressed Edit → Delete All Data And Download, but the data still stops at the dates mentioned. Question: Is this a limitation of the historical data available for this contract? Or is there an issue with my data feed / symbol settings? If necessary, please advise which symbol has full historical intraday + daily backfill for NQ CME Futures. Thanks. |
| [2025-11-27 16:45:17] |
| TonyCipriani - Posts: 155 |
Under Chart Settings > Data Limiting, in the Date Range in File From, try to input a date to how far back you want to go. See if that works.
| [2025-12-01 15:35:21] |
| John - SC Support - Posts: 48555 |
It sounds like you are not using a Continuous Futures Contract. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
