Date/Time: Wed, 25 Nov 2026 21:24:11 +0000
Add LSE symbol
View Count: 429
[2025-11-25 15:24:13]
User266678 - Posts: 23
I have a London Stock Exchange market data subscription with IBKR. However, I cannot find the relevant symbols traded on LSE (for example, the EZJ stock). How can I solve this?
imageScreenshot 2025-11-25 at 16.23.53.png / V - Attached On 2025-11-25 15:24:06 UTC - Size: 185.81 KB - 124 views
[2025-11-25 15:33:48]
You will not find those symbols in the "Find Symbol" window within Sierra Chart. You need to know what the symbol is for Interactive Brokers and enter that symbol in the "Selected Symbol" field on the Find Symbol window then you can open the appropriate type of chart you want.
[2025-11-25 16:10:54]
Got it, thanks, I used this to input the correct symbol format
Interactive Brokers Symbols: Stock Format
