Date/Time: Wed, 25 Nov 2026 21:24:20 +0000
Number bars
View Count: 339
| [2025-11-23 22:45:41] |
| User575399 - Posts: 351 |
Is it possible to show the candlestick NEXT TO the number bars instead of overlapping it?
| Attachment Deleted. |
| [2025-11-23 23:02:56] |
| Sierra_Chart Engineering - Posts: 25483 |
Are you using an overlay study for those candlestick bars? The answer to the question is no. We recommend using this Input setting and you have various choices, for the open/close boxes: Numbers Bars: Open and Close Marker Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
