Date/Time: Wed, 25 Nov 2026 22:26:25 +0000
Linked charts issue
View Count: 485
[2025-11-22 01:36:31]
cuckiecheese - Posts: 119
I've got 6 chart tabs all linked by the same number. 5 of the charts have "days to load" linked. whenever I make a change to days to load on the unlinked chart it affects and changes all of the days to load on linked charts. This does not happen the other way around (as expected).
[2025-11-24 15:12:03]
What you are stating is how the Linking works, as they share the same link number. Refer to the following:
Chart Settings: Setting Same Linking Options Across All Linked Charts
There is work ongoing right now to update how the linking works that will allow you to do what you want. We can not say, however, when this will be available.
[2025-11-24 17:37:40]
What's the expected behavior tho if all the charts have the same link number but one(or more) of the charts has different linked characteristics? (days to load, symbol, etc)
[2025-11-24 20:13:25]
This is covered in the documentation we pointed you to. Here it is again:
[2025-11-24 20:56:14]
ah ok i see now, I had to enable mastermode on the one chart to prevent the other charts from changing
