Date/Time: Wed, 25 Nov 2026 21:24:17 +0000
C++ Classic V1
View Count: 515
[2025-11-21 21:41:32]
User108811 - Posts: 14
is Classic V1 the most up to date code i can write in?
[2025-11-21 21:57:44]
We do not know what you are referring to in terms of Classic V1.
If you compile your own code, then any C++ version can be used.
Our Remote Compiler option supports C++20.
[2025-11-21 22:02:38]
yes i'm trying to compile and it doesn't like newer language to code. is there a separate program i have to download in order to be able to compile correctly?
[2025-11-21 22:43:20]
You would have to compile the DLL yourself using your own compiler. To do this, you select "Build >> Build with Visual C++ - Release" (or Debug) on the menu for the "Build Advanced Custom Studies" window.
When you do this, the system calls the file "VisualCCompile.Bat" located in the ACS_Source folder under your main Sierra Chart installation folder. You can set the compiler and any switches in that file.
[2025-11-22 16:27:10]
The About window shows "SC Data", which I believe means I'm not receiving the developer-enabled version.
Please enable the full Sierra Chart version with ACSIL compiling / Build menu for my account, or provide the correct installer.
[2025-11-22 17:26:27]
User431178 - Posts: 910
Your AI is misleading you.
There is no such thing as developer-enabled version.
1. Analysis >>> Build
2. Build >>> Build with Visual C++ - Release (as John - SC Support wrote above)
Analysis Menu: Build Advanced Studies DLL
Is it the same problem with your code that won't compile, hallucinations?
