Date/Time: Tue, 03 Nov 2026 17:43:06 +0000
Delayed DOM data
View Count: 445
| [2025-11-21 09:55:35] |
| AC96354 - Posts: 21 |
Hello. Id like to watch delayed DOM data for EUREX. I payed for package, open DOM with DAX symbol. But it is blank, no delayed data. |
| [2025-11-21 15:18:32] |
| John - SC Support - Posts: 48408 |
There is no reason for you to not be able to get the delayed streaming data for EUREX. What are the following set to: - Global Settings >> Data/Trade Service Settings >> Common Settings >> Current Selected Service - Chart >> Chart Settings >> Symbol >> Symbol (for the chart that is not showing data) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-21 16:20:57] |
attached file. Depth of market is blank
Date Time Of Last Edit: 2025-11-21 16:21:07
| [2025-11-21 16:29:26] |
We need to see your entire Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-21 17:10:19] |
Software version: 2451 64-bit | 2025-11-21 17:09:03.052 Primary Thread ID: 4148 | 2025-11-21 17:09:03.052 Usage end date: 2025-12-17 | 2025-11-21 17:09:03.052 Enabled for: Sierra Chart Historical Data Service. | 2025-11-21 17:09:03.052 Enabled for: Delayed Denali Exchange Data Feed. | 2025-11-21 17:09:03.052 Allow Support for Sierra Chart Data Feeds is enabled. | 2025-11-21 17:09:03.052 Current selected Data/Trading service: SC Data - All Services | 2025-11-21 17:09:03.052 Custom symbol settings values: enabled | 2025-11-21 17:09:03.052 Chart Update Interval: 500 | 2025-11-21 17:09:03.052 Intraday Data Storage Time Unit: 1 | 2025-11-21 17:09:03.052 Time Zone: +00:00:00 (UTC+00) | 2025-11-21 17:09:03.052 2025-11-21 17:09:03 Local computer time in UTC | 2025-11-21 17:09:03.052 2025-11-21 17:09:03 Local computer time in SC Time Zone | 2025-11-21 17:09:03.052 2025-11-21 17:07:18 Server time in UTC | 2025-11-21 17:09:03.052 Local computer UTC time and Server UTC time difference: 0 seconds. | 2025-11-21 17:09:03.052 Program path: D:\SC_A\ | 2025-11-21 17:09:03.052 Data Files path: D:\SC_A\Data\ | 2025-11-21 17:09:03.052 OS Version Number: 6.1 | 2025-11-21 17:09:03.052 Locale Setting: C | 2025-11-21 17:09:03.052 Allowed protected custom studies: | 2025-11-21 17:09:03.052 Crash reporter started: true | 2025-11-21 17:09:03.052 File >> Disconnect selected. | 2025-11-21 17:09:22.251 SC Data - All Services | Disconnected. | 2025-11-21 17:09:22.251 SC Data - All Services | Connected to server complete. | 2025-11-21 17:09:25.611 Triggering next historical data download in queue. | 2025-11-21 17:09:25.611 Triggering next historical data download in queue. | 2025-11-21 17:09:25.611 Triggering next historical data download in queue. | 2025-11-21 17:09:25.611 Triggering next historical data download in queue. | 2025-11-21 17:09:25.611 No download requests in the queue to start downloads for. | 2025-11-21 17:09:25.611 No download requests in the queue to start downloads for. | 2025-11-21 17:09:25.611 No download requests in the queue to start downloads for. | 2025-11-21 17:09:25.611 No download requests in the queue to start downloads for. | 2025-11-21 17:09:25.611 Mapping FESXZ25-EUREX to FESX202512_FUT_EUREX. Service code: eurex | 2025-11-21 17:09:25.956 Using symbol data fast lookup vector | 2025-11-21 17:09:25.956 SC DTC Delayed Exchange Data | Starting real-time market data updates for: FESXZ25-EUREX (FESX202512_FUT_EUREX). ID: 1 Service code: eurex | 2025-11-21 17:09:25.957 SC DTC Delayed Exchange Data | Connecting to the server ds24.sierracharts.com. Port 10043 | 2025-11-21 17:09:25.957 SC DTC Delayed Exchange Data | Requesting security definition data for: FESXZ25-EUREX (FESX202512_FUT_EUREX). ID: 1 | 2025-11-21 17:09:25.957 Added historical Intraday data request for FESXZ25-EUREX to the queue. | 2025-11-21 17:09:25.957 Intraday data recording state for symbol FESXZ25-EUREX is set to download 'Pending'. | 2025-11-21 17:09:25.957 Triggering next historical data download in queue. | 2025-11-21 17:09:25.957 DTC Client socket (7) | Creating socket. | 2025-11-21 17:09:25.957 DTC Client socket (7) | New receive buffer size: 5242880 | 2025-11-21 17:09:25.957 DTC Client socket (7) | Connecting to IP: 62.209.53.226. | 2025-11-21 17:09:25.957 Delaying start of download for FESXZ25-EUREX. | 2025-11-21 17:09:25.959 SC DTC Delayed Exchange Data | Network connection to server complete. | 2025-11-21 17:09:26.005 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2025-11-21 17:09:26.005 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2025-11-21 17:09:26.005 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2025-11-21 17:09:26.062 SC DTC Delayed Exchange Data | Sending logon request message. | 2025-11-21 17:09:26.062 SC DTC Delayed Exchange Data | Received logon response. | 2025-11-21 17:09:26.110 SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2025-11-21 17:09:26.110 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2025-11-21 17:09:26.110 SC DTC Delayed Exchange Data | Connection error: Invalid login data.. | 2025-11-21 17:09:26.110 * SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2025-11-21 17:09:26.110 DTC Client socket (7) | CloseSocket call. | 2025-11-21 17:09:26.110 SC DTC Delayed Exchange Data | Disconnected from the server. | 2025-11-21 17:09:26.110 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2025-11-21 17:09:26.110 DTC Client socket (7) | Socket gracefully closed by remote side. | 2025-11-21 17:09:26.153 DTC Client socket (7) | Closed. | 2025-11-21 17:09:26.153 Requesting market depth updates for: FESXZ25-EUREX if supported. | 2025-11-21 17:09:30.605 Separate subscription for market depth updates not supported. FESXZ25-EUREX | 2025-11-21 17:09:30.605 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2025-11-21 17:09:38.069 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2025-11-21 17:09:38.069 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2025-11-21 17:09:38.069 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2025-11-21 17:09:38.069 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2025-11-21 17:09:38.069 HD Request # 2 | Downloading Intraday chart data for FESXZ25-EUREX to the file FESXZ25-EUREX.scid. Service: eurex | 2025-11-21 17:09:56.470 HD Request # 2 | Download start date-time: 2025-11-21 16:53:22.000000. File last date-time: 2025-11-21 16:53:22.157000 | 2025-11-21 17:09:56.470 HD Request # 2 | Using server: ds14.sierracharts.com port 10150 | 2025-11-21 17:09:56.470 Socket (7) | Creating socket. | 2025-11-21 17:09:56.471 Socket (7) | New receive buffer size: 5242880 | 2025-11-21 17:09:56.471 Socket (7) | Connecting to IP: 176.9.9.252. | 2025-11-21 17:09:56.471 HD Request # 2 | Setting DTC encoding to Binary VLS | 2025-11-21 17:09:56.558 HD Request # 2 | Sending historical data logon request message. | 2025-11-21 17:09:56.558 HD Request # 2 | Requesting Intraday data. Start date-time: 2025-11-21 16:53:22. Record interval: 1. Symbol: FESX202512_FUT_EUREX | 2025-11-21 17:09:57.094 HD Request # 2 | Decompressing data. | 2025-11-21 17:09:57.138 HD Request # 2 | Receiving Intraday data for FESXZ25-EUREX starting at 2025-11-21 16:53:22.157000 | 2025-11-21 17:09:57.180 Socket (7) | CloseSocket call. | 2025-11-21 17:09:57.182 Socket (7) | Shutdown started. Waiting for graceful close. | 2025-11-21 17:09:57.182 Historical data download thread signaled to stop. | 2025-11-21 17:09:57.182 HD Request # 2 | Timestamp of first Intraday data file record written: 2025-11-21 16:53:22.157000. | 2025-11-21 17:09:57.182 HD Request # 2 | Received 47 Intraday data records from 2025-11-21 16:53:22.157000 to 2025-11-21 16:55:00.000000 (97.8 seconds) and wrote 47 records for FESXZ25-EUREX | 2025-11-21 17:09:57.182 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-11-21 16:55:00.000000 | 2025-11-21 17:09:57.182 HD Request # 2 | Completion time: 1s. | 2025-11-21 17:09:57.182 HD Request # 2 | Intraday data download complete for FESXZ25-EUREX. Unique request ID: 2 | 2025-11-21 17:09:57.182 Removing historical data download ID 2. | 2025-11-21 17:09:57.182 Real-time Intraday chart data file updates started for FESXZ25-EUREX | 2025-11-21 17:09:57.182 Opened cached Intraday file: D:\SC_A\Data\FESXZ25-EUREX.scid. Thread ID: 4148 | 2025-11-21 17:09:57.183 Intraday chart data file opened for FESXZ25-EUREX | 2025-11-21 17:09:57.183 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2025-11-21 17:09:57.183 Triggering next historical data download in queue. | 2025-11-21 17:09:57.183 No download requests in the queue to start downloads for. | 2025-11-21 17:09:57.183 Socket (7) | Socket gracefully closed by remote side. | 2025-11-21 17:09:57.224 Socket (7) | Closed. | 2025-11-21 17:09:57.224 |
| [2025-11-21 17:23:13] |
chart is not updating (refreshing)
| [2025-11-21 19:21:20] |
You are on a very old version of the software. You must update to the current version in order to be able to get the data properly. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
