Date/Time: Sat, 27 Apr 2024 17:08:37 +0000
Chart Caculator & Time Difference
View Count: 2261
[2013-03-24 18:35:58] |
WarriorTrader - Posts: 245 |
Hello, I am using ACSIL to draw the Chart Caculator tool. The "Time Difference" is no longer working. It is displaying zeroes. Thx, WT Date Time Of Last Edit: 2013-03-25 01:25:35
[2013-03-25 20:27:48] |
Here is a picture https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=87 WT |
3-21 DeltaLine error.png / V - Attached On 2013-03-25 20:23:20 UTC - Size: 111.99 KB - 958 views Attachment Deleted. |
[2013-03-25 20:42:41] |
This really is not clear for us. How many bars does the chart calculator line span? You need to provide an image with just one very clear line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-26 03:50:36] |
The length of the Chart Calculator can vary: Anywhere from a length of 1 to a length of over 100. You can pick any length you like. It does not matter if it is drawn in the price chart or the delta study, the time difference comes up with zeros. A manually drawn Chart Calculator works well. It is only a problem within ACSIL. There were no problems in 949. It broke somewhere after 949 or so. Do you really need another image? Not sure how that will help you. --WT |
[2013-03-26 03:53:17] |
InvGrabLineLow_Tool.Clear();
InvGrabLineLow_Tool.ChartNumber = sc.ChartNumber; //InvGrabLineLow_Tool.DrawingType = DRAWING_LINE; InvGrabLineLow_Tool.DrawingType = DRAWING_CALCULATOR; InvGrabLineLow_Tool.ShowPriceDifference=1; InvGrabLineLow_Tool.ShowTimeDifference=1; InvGrabLineLow_Tool.LineNumber = 3431345; InvGrabLineLow_Tool.AddMethod = UTAM_ADD_OR_ADJUST; InvGrabLineLow_Tool.TextAlignment = DT_VCENTER | DT_RIGHT; //DT_VCENTER InvGrabLineLow_Tool.BeginIndex= SavedBeginIndex; InvGrabLineLow_Tool.EndIndex= sc.Index; //InvGrabLineLow_Tool.BeginDateTime = sc.BaseDateTimeIn[ChartDrawing.BeginIndex]; //VisOffset; //sc.BaseDateTimeIn[sc.ArraySize]; //InvGrabLineLow_Tool.EndDateTime = sc.BaseDateTimeIn[sc.Index]; InvGrabLineLow_Tool.LineStyle = LINESTYLE_DOT; InvGrabLineLow_Tool.LineWidth = 1; InvGrabLineLow_Tool.FontBackColor = RGB(255,255,255); InvGrabLineLow_Tool.BeginValue = sc.BaseData[SC_LOW][SavedBeginIndex]; InvGrabLineLow_Tool.EndValue = sc.BaseData[SC_LAST][sc.Index]; InvGrabLineLow_Tool.Color = RGB(219,137,137); sc.UseTool(InvGrabLineLow_Tool); |
[2013-03-27 00:36:29] |
Testing this now.
[2013-03-27 00:59:49] |
This will be resolved in the next release.
