Date/Time: Wed, 09 Sep 2026 09:47:26 +0000
"Old" v "New" Spreadsheet
View Count: 1335
| [2014-10-16 02:35:17] |
| User80177 - Posts: 29 |
Questions and a suggestion on SC versions and spreadsheets: 1. Where can I download SC version 1174 with the old spreadsheet? Download page http://www.sierrachart.com/index.php?page=doc/SCInstallerList.php does not indicate which version of spreadsheet is included. 2. If I had inadvertently opened an "old" spreadsheet and then saved it with a "new" spreadsheet version, would it still be readable by an "old" spreadsheet version? 3. A suggestion: Provide a warning and an option to auto-rename a chart or spreadsheet when being saved as a new version that may be unreadable by an older version. While SC automatically creates backups, a version identifier will make it more useful. Thanks |
| [2014-10-16 03:07:46] |
1. Use this one: http://www.sierrachart.com/downloads/1174.1SierraChartSetupPrerelease.exe If the installer does not have the words "No CLR" , then it has Old Spreadsheets. 2. Yes. 3. There is no need for this because new Spreadsheets use a different file extension. It is SCSS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-16 03:10:11
