Date/Time: Wed, 25 Nov 2026 21:24:13 +0000
Options on futures prices
View Count: 435
| [2025-11-17 14:23:07] |
| User944318 - Posts: 65 |
I am currently using Teton for data and am able to get the current price of ES options. If I switch to rithmic, will I still be able to access this data?
| [2025-11-18 07:22:47] |
| Sierra_Chart Engineering - Posts: 25483 |
Not totally sure. Maybe not but you can install another version of Sierra Chart for Rithmic: Using Multiple Data and Trading Services at the Same Time To keep it separate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-18 07:22:57
| [2025-11-18 12:03:55] |
If not able to, would I be able to use the data from teton, but place orders through rithmic? Also what would be the deciding factor if rithmic offers this or not? How can I investigate further without committing to rithmic?
| [2025-11-18 19:06:34] |
In order to get Options data from our Denali Exchange Data Feed while connected to Teton, follow these instructions: Denali Exchange Data Feed: Denali Futures Options with Sierra Chart Services If you are connected to Rithmic, then you can still get the Options data from our Denali Exchange Data Feed by following these instructions: Denali Exchange Data Feed: Denali Exchange Traded Spread Data with Trading Service We can not say how Rithmic does with handling Options orders. If they state that they can do this, then you should be able to do what you want with them and our Denali Exchange Data Feed. But you would have to commit to Rithmic in order to test it out with them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
