Date/Time: Wed, 25 Nov 2026 21:06:22 +0000
How to permanently stop P0944 NT Bot Tester
View Count: 323
| [2025-11-16 22:17:11] |
| User396 - Posts: 61 |
Third Party Studies Enabled For Account [Link] - [Top] If Sierra Chart is running in Safe Mode, then the Enabled Studies cannot be used. DLL Name: P0944 NT Bot Tester. I do not want this DLL file anymore but I do not see any control to do that? Thank you, b396 |
| [2025-11-16 22:21:00] |
| Sierra_Chart Engineering - Posts: 25483 |
We have removed, access to the study for you. Also go into the Sierra Chart Data Files Folder: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) And delete the DLL with that same name. But the name of the DLL could be a little different. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
