Date/Time: Wed, 25 Nov 2026 21:06:18 +0000
Feature Request - More flexible Configuration For Order Allocation
View Count: 367
| [2025-11-16 13:48:19] |
| gambcl - Posts: 18 |
The Order Allocation feature is great for copying to follower accounts, but it could easily be made so much more useful. Suppose I don't want to trade 20 Apex accounts together in one group, but maybe in groups of 5. At the moment I would either have to: - go into Order Allocation settings and change the follower list each time I switch groups - or setup a new instance of SierraChart for each group, which seems very heavyweight for what could simply be a config upgrade. It would be perfect if we could define multiple leader accounts, and then each leader account has its own set of follower accounts. Ideally I can choose 4 leader accounts, and simple switch between them in the trade panel, and know that the order allocation will then copy into the relevant follower accounts. |
| [2025-11-16 20:33:48] |
| Sierra_Chart Engineering - Posts: 25483 |
The Order Allocation to Trade Account settings is supported to be saved with the Trade Window configurations. So what you want is already very well supported: Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Save Trade Window Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-16 20:33:57
