Date/Time: Wed, 25 Nov 2026 21:06:17 +0000
Replay calculate time
View Count: 360
| [2025-11-15 22:48:26] |
| User169205 - Posts: 72 |
hello, i have noticed that when i click Replay on my chartbook, it is now taking about 3-4 minutes to calculate and run. This was not the case about a year ago. I have not changed my chartbook. I am using the 64bit version and have plenty of RAM. The speed to calculate has slowed considerably. Also, Replay will start about 15 minutes away from the time point i originally selected. Please advise.
| [2025-11-16 18:35:08] |
| Sierra_Chart Engineering - Posts: 25483 |
Reduce the amount of data loaded in the charts.: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.1 - Too Much Data to Load or Loaded Also, use a 1 second or higher Intraday Data Storage Time Unit, instead of tick by tick: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.12 - Intraday Data Storage Time Unit. Historical Data Record Time Frame. Review the other items on that page: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often This probably relates to the amount of time to load the chart data: Also, Replay will start about 15 minutes away from the time point i originally selected
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-16 18:36:19
