Date/Time: Wed, 25 Nov 2026 21:06:13 +0000
Anfrage Chance Risko Tool
View Count: 355
| [2025-11-13 18:07:48] |
| User437588 - Posts: 93 |
Hallo Gibt es ein Change Risiko Study oder Tool die wie ein Fibonacci Retracement genutzt werden kann? |
| [2025-11-13 18:17:18] |
| John - SC Support - Posts: 48659 |
From Google Translate: Hello
Is there a change risk study or tool that can be used like a Fibonacci retracement? We are not certain of what exactly you are looking for, but check the "Reward/Risk" tool: Chart Drawing Tools: Reward/Risk For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-13 18:46:17] |
Genau danach habe ich gesucht. Besten Dank |
