Date/Time: Wed, 25 Nov 2026 21:06:17 +0000
Rectangle ‘Options >> Use End Time’
View Count: 393
[2025-11-13 00:52:32]
faidzal1982 - Posts: 12
In the documentation for ‘ Rectangle | Extending Rectangle | Ellipse | Triangle Configuration’ below, there is ‘Options >> Use End Time’. Is this available? I can’t see it in the settings for Rectangle.
Chart Drawing Tools: Tool Settings
[2025-11-13 15:53:49]
John - SC Support - Posts: 48659
For the "Rectangle" drawing configuration there are the following:
- Use Start Time
- Start Time
- Use End Time
- End Time
The "Start Time" and "End Time" are only available if the respective options are set to "Yes" first.
Keep in mind that these items will only show in the Configuration for Rectangle. The Properties of an existing rectangle will not have these. If you want to set a specific start or end time for an existing rectangle, then you need to change the Anchor values.
[2025-11-13 22:54:27]
Thank you. I’ve found the settings.
