Date/Time: Wed, 25 Nov 2026 21:24:13 +0000
Trades data not available
View Count: 631
[2025-11-12 02:04:51]
User124881 - Posts: 20
hi there i am trying to upload my trades on tradezella a journaling software but i can't find my trades my new account doesn't have any trades and am trying to change the acount but it still the same am using a prop firm i use to export my trades now i can't find my historical trades
image12.png / V - Attached On 2025-11-12 01:58:45 UTC - Size: 71.23 KB - 218 views
image13.png / V - Attached On 2025-11-12 01:58:56 UTC - Size: 120.65 KB - 207 views
image14.png / V - Attached On 2025-11-12 02:00:28 UTC - Size: 104.75 KB - 138 views
[2025-11-12 15:12:32]
In order to get Chart Stats, the charts themselves need to be set to the specific information you are looking for. From what you show, your charts must be set to the Trade Account that is showing in the Chart Stats. Be sure to set the account for the individual charts for what you want to see in the Chart Stats. Refer to the following:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
Also, the Statistics will be limited by what is set in the [DisplaySettings] but the Chart Stats are going to be based on what is actually associated with the chart. So this can be different.
[2025-11-12 21:49:43]
thank you i set it up now i can see my trades and i was able to upload it but the execution time is different then the time i took the trade
example like today how do i change it
image2025-11-12_14-47-05.png / V - Attached On 2025-11-12 21:48:35 UTC - Size: 2.77 MB - 141 views
image2025-11-12_14-38-41.png / V - Attached On 2025-11-12 21:48:50 UTC - Size: 129.74 KB - 192 views
[2025-11-12 22:02:00]
If you use the "File >> Save Log As" option, then the dates/times will stay as they show in the Trade Activity Log.
If you use the "File >> Export" option, then the dates/times are changed to be in the UTC time zone. This makes it so that data can be reimported into the system and the dates/times correctly dealt with.
Trade Activity Log: Saving to a Text File
Trade Activity Log: Importing and Exporting Data
[2025-11-12 22:50:29]
beside Export or Importtrades my trades don't match my time zone
how do i change that and the Trade Activity Log: Importing and Exporting Data shows no data
image2025-11-12_15-39-06.png / V - Attached On 2025-11-12 22:49:11 UTC - Size: 49.55 KB - 131 views
image2025-11-12_14-47-05.png / V - Attached On 2025-11-12 22:49:26 UTC - Size: 2.77 MB - 305 views
[2025-11-13 14:57:43]
The Trade Activity Log uses the Global Time Zone to display the times for the trades. It has to do this, as you could have charts with different time zones. The Global Time Zone is set in "Global Settings >> Time Zone". Refer to the following:
Time Zone Setting
[2025-11-14 21:25:20]
i don't understand are you saying if i change the time zone on my execution chart than my my trades time will change?
[2025-11-14 23:11:29]
At this point we are very confused. At the present moment what is the issue that you are having? And there is no need to post any images. This is so complicated and lacks, a necessary commentary, it is of no use to us:
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=129515
And it is important to understand, that when you export data from the Trade Activity Log, the timestamps are always in the UTC time zone
Date Time Of Last Edit: 2025-11-14 23:11:56
[2025-11-17 02:52:42]
yes i understand that the question is how i can change the time zone from the Trade Activity Log to matched my execution chart because the timestamps of my trade is different then the timestamp on my if you at the picture i sent i have circled the different, am sure the should match?
[2025-11-17 11:27:46]
What is the time zone that your execution chart is set to?
[2025-11-21 01:35:02]
chicago (-6 CST/-5 CDT)
[2025-11-21 15:08:12]
And how did you export the data from the Trade Activity Log?
[2025-11-22 00:02:43]
Go the Trade Activity tab.
Select Fills from the dropdown and hit Apply.
Use the filtering controls at the top of the log to display the trades you want to import.
Select File from the header then, Save Log As, and save the log as a text file to your desktop.
Here on the import window, click "Choose file", choose the file you created above, and click "Import".
and beside this the TAL time zone is also different then the execution chart trade time i can send you a screenshot
