Date/Time: Wed, 25 Nov 2026 21:06:15 +0000
Assistance with "Bar Duration" Alert in Numbers Bars Calculated Values Study
View Count: 328
| [2025-11-11 17:34:02] |
| User951086 - Posts: 30 |
I intend to set an alert for the “Bar Duration” variable in the “Numbers Bars Calculated Values” study. Specifically, I would like to hear an alert sound when the value of the “Bar Duration” variable in the study for the closed candle is less than 3 seconds. To achieve this, I entered the condition SG30 < 3 in the Alerts tab. However, this condition does not produce the desired alert. My understanding is that Sierra Chart may be interpreting one second as a different numerical value. Could you please advise what adjustment I should make to the alert condition so that it functions as intended (i.e., triggers when the closed candle’s Bar Duration value in the Numbers Bars Calculated Values table is less than 3 seconds)? |
Attachment Deleted. |
| [2025-11-11 18:54:05] |
| John - SC Support - Posts: 48659 |
Refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
