Date/Time: Wed, 25 Nov 2026 21:06:17 +0000
Stop run indicator
View Count: 519
| [2025-11-11 17:03:53] |
| kalyaan - Posts: 5 |
Hi, Sierra has stop run indicator? That gives the line or dots to where we can safely put the stop loss. This indicator calculates stop loss based on order flow. Appreciated your help. Thank you 🙂 |
| [2025-11-11 18:51:12] |
| John - SC Support - Posts: 48659 |
We do not have a study that has the name "Stop Run". Depending on what it does, you may able to create it using the existing studies or a Spreadsheet Study. Worst case, you can always create a custom study yourself (or pay someone to do it) that does what you want. Refer to the following: Technical Studies Reference Advanced Custom Study Interface and Language (ACSIL) https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
