Date/Time: Mon, 23 Nov 2026 07:12:37 +0000
Mapped MES to ES data, but P&L showing ES. scared to go live...
View Count: 447
| [2025-11-10 14:58:04] |
| User172061 - Posts: 36 |
Hi there, for some reason today when im trading the DPL says +2p, and im trading MES mapped to ES. but the statistics show +100. also my daily loss limit and auto flatten happened because its showing up as 10x my normal rates. quantity is set to 1 for my trade Symbol (action) is set to ESZ25_FUT_CME Trade & Current Quote Sumbol (Action) is set to MESZ25_FUT_CME for the trade activity log it says Symbol [SIM] MESZ25_FUT_CME Chart (the name of my chart) Daily P&L 100.00 Total fills (daily) 6 (i had 1 scratch, 1 1.25p and 1 .75p) Last trade P/l 37.50 assistance would be appreciated. |
| [2025-11-10 14:59:05] |
heres another log... (Log removed) Date Time Of Last Edit: 2025-11-10 15:41:16
| [2025-11-10 15:40:38] |
| Sierra_Chart Engineering - Posts: 25463 |
Refer to: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss And also refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-10 15:53:57] |
everything appears correct from what i can tell. also FWIW im not the only person this appears to be happening to, another person in a trading group im with posted a support issue about this in our discord..hes also trading on SIM for what its worth... both of us it was working just fine last week.
| [2025-11-10 16:43:37] |
| John - SC Support - Posts: 48610 |
Also check your "Currency Value per Tick" and make sure it is set appropriately for the "Trade and Current Quote Symbol". Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-10 18:54:38] |
that was it. will LYK if live trading is off, but for sim purposes anyway it seems great. Thanks so much for your help John.
