Date/Time: Tue, 20 Oct 2026 18:28:53 +0000
Real time data issues - Followed every step!
View Count: 368
| [2025-11-06 18:46:06] |
| nsc21821 - Posts: 7 |
I followed every step, paid for the Denali data (cme bundle exchanges), connected to my real trading account as a requirement, have enabled the option of "allow support for SC data feed" and Still not able to see the markets in real time, very frustrationg. can you take a look into this on my account please?
| [2025-11-06 19:15:32] |
| John - SC Support - Posts: 48273 |
Everything on your account looks good, so you should be getting the real-time data for any product traded on the CME Group, per the exchange that you have active. What are you seeing that makes you state that you are getting delayed data? Please get us your Message Log by following these instructions exactly (make sure you only open a chart for a single symbol): Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
