Date/Time: Wed, 25 Nov 2026 20:51:58 +0000
ZB
View Count: 407
| [2025-11-06 16:21:24] |
| sasha - Posts: 6 |
Hello. Why is my ZB futures showing 10 minutes later, I have everything paid for and connected? Thank you
| [2025-11-06 18:58:47] |
| John - SC Support - Posts: 48658 |
You have the "CME with Market Depth for Non-Professional Trading Accounts" exchange active. ZB is traded on the CBOT. To get the real-time data, you need to add or change your exchange options so you are setup to get the data for CBOT, along with whatever other exchanges you may need. Refer to the following: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
