Date/Time: Wed, 25 Nov 2026 20:52:00 +0000
windows problem keeps evolving
View Count: 485
| [2025-11-06 14:21:34] |
| Lucas Muench - Posts: 28 |
Hey guys, I know youre working on it but this problem seems to be evolving, for the first time yesterday i couldnt even reset the windows with the global settings anymore and all my tabs and windows were gone, sierrachart was basically unusable. probaly no solution right now but (at least for me) seems to be getting worse. |
| [2025-11-06 18:37:49] |
| John - SC Support - Posts: 48658 |
What specific windows did not reset, and what reset option did you use (there are two, one under Chart for Chart Child Windows and one under Windows for top-level windows). If the Tabs are not showing, and none of the charts are showing, then select the "CW" menu and see if any charts are listed in there. If so, then select one from there and see if it will come up. We wonder if the charts are just temporarily hidden, which we do see happen occasionally for no particular reason. Also, you can do an Internet Search for "move windows off screen" and you will find plenty of posts about how to get a window back that is off-screen. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-06 19:09:35] |
I used global settings and then changed position of charts from top to bottom then it was reappearing before
| [2025-11-06 19:17:20] |
We assume you are referring to the MDI Tabs (that show the charts in your chartbook)? Are these still not showing up after changing the position of the tabs? Are there other windows for which you are having an issue, or just these tabs? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
