Date/Time: Wed, 25 Nov 2026 20:51:52 +0000
how do I create this?
View Count: 389
[2025-11-06 09:56:50]
User849502 - Posts: 485
Morning John, Yesterday SC reposted a post on X by Jester(who I am now following) with a great chart which shows a volume profile on the left, and and delta profile on right. I asked him on X if that's what those were and he said yes. I have tried googling it, and fiddling, and asked him on X if he would sell that. I thought I might just ask you if you knew how I could make this. It obvs is footprint but beyond that my blond brain doesn't work. I can't figure out how you attach them so they are side by side. Any ideas? Appreciate your time, as always. Karen
imagejesterchart.png / V - Attached On 2025-11-06 09:56:02 UTC - Size: 879.08 KB - 168 views
[2025-11-06 15:28:41]
John - SC Support - Posts: 48658
That is done with the "Numbers Bars" study. You need to setup Column 1 to display a "Right Aligned Volume Profile" and Column 2 to be a "Volume Profile". Refer to the following:
Numbers Bars: Numbers Bars Background Types
[2025-11-06 15:30:52]
I loooooooooooooove you, thanks mate
