Date/Time: Sun, 05 May 2024 23:13:47 +0000
6E data was down for 3-5 minutes?
View Count: 820
[2014-10-15 13:02:23] |
BJV - Posts: 29 |
Can you provide some feedback on this?..thanks
[2014-10-15 16:18:41] |
We see you are using the Sierra Chart Exchange Data Feed. While the exact reason at this time is not known for this interruption today, we are working on a solution for the underlying cause. If you notice this again, select File >> Disconnect and File >> Connect to Data Feed to switch to another server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
