Date/Time: Wed, 25 Nov 2026 20:51:56 +0000
two instances
View Count: 316
[2025-11-04 12:37:19]
lservin29 - Posts: 78
hello,
I run two separate instances of SC, one for ES and another for NQ. all of my NQ intraday chart have been showing empty gaps on NQ instance, when I change the symbol on ES instance to NQ the gaps do NOT exist. this is happening across multiple intraday CBs. what setting could it be?
imageNQ gap.jpg / V - Attached On 2025-11-04 12:37:09 UTC - Size: 180.21 KB - 171 views
[2025-11-04 14:41:11]
John - SC Support - Posts: 48658
Most likely it is your Session Times not set the same between the two instances, and also not covering the full trading hours. Refer to the following:
Chart Session Times
