Date/Time: Wed, 25 Nov 2026 20:52:12 +0000
Time Frames
View Count: 527
| [2025-10-30 14:22:03] |
| yannickAnvo - Posts: 7 |
Hi I would like to be able to have custom Time frames such as 7min, 6min. the Custom button does not give the opportunity to do so.
| [2025-10-30 15:09:51] |
| John - SC Support - Posts: 48658 |
There are 50 Control Bar buttons that can be configured to any Bar Period you want. They are under "Chart Bar Period" and show as "Custom Bar Period #". Select one, and add it to a Control Bar, then select the "Set Period..." button at the bottom of the Control Bar configuration window and set the bar period you want. Refer to the following: Control Bar: Custom Buttons for Intraday Chart Bar Period There are no Keyboard Shortcuts that can be setup for custom bar periods, but refer to the following for other ways you can change the Bar Period, including options for keyboard entry: Changing Chart Bars Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-31 18:02:45] |
is there a measurement tool i can use to measure points on the chart?
| [2025-10-31 18:41:44] |
Refer to the following: Chart Drawing Tools: Chart Calculator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
