Date/Time: Wed, 25 Nov 2026 16:39:22 +0000
Study/Price Overlay
View Count: 529
[2025-10-30 01:04:16]
Shink22 - Posts: 21
Hello, attached is a picture of my chart where I have the 1 minute timeframe with the study "Study/Price Overlay" overlaying a 15 minute chart. It overlays the 15 minute candle 15 times for each minute represented in the 15 minute candle. Is there a way to make it just one candle for the 15 minute period? Thank you.
imageMTFA.JPG / V - Attached On 2025-10-30 01:02:26 UTC - Size: 192.64 KB - 202 views
[2025-10-30 13:57:58]
In the "Study/Price Overlay" set the Input for "Fill Blanks with Last Value" to "No". Refer to the following:
Study/Price Overlay Study: Fill Blanks with Last Value
[2025-10-30 14:51:31]
Shink22 - Posts: 21
Thanks that got it down to one candle. Is there a way to make it encompass the whole 15 min period instead of one 1 min candle width?
[2025-10-30 15:26:10]
Try the option for "Use Multicolumn Rectangle Style for Price Bars" and see if it will do what you want. Refer to the following:
Study/Price Overlay Study: Use Multicolumn Rectangle Style for Price Bars
[2025-10-30 15:42:26]
Shink22 - Posts: 21
That just makes a solid block from high to low and not ohlc.
[2025-10-30 16:41:34]
It sounds like what you are looking for is what you had initially. If that is not what you want, then there are no other options, apart from displaying the overlay in a separate region.
[2025-10-30 16:53:01]
Shink22 - Posts: 21
I've attached an example of how I would like it to look from tradingview. I use sierra chart and if it works sierra would be superior as it's the only platform that allows for the higher timeframe to be displayed behind the lower timeframe. Every platform has both timeframes on the same z axis and you really don't get the optimal visual display. If it's not currently available I would like to request support for this. Multiple time frame analysis on one chart seems to be pretty popular but so far nobody has perfected it and this implementation would do so. Thank you.
imagetvmtfa.JPG / V - Attached On 2025-10-30 16:51:17 UTC - Size: 57.04 KB - 171 views
[2025-10-30 18:39:00]
We understand what you are looking for, and this is not currently supported fully. As you saw, it is close with the "Multicolumn Rectangle", but not fully what you are wanting.
We have noted this as a Feature Request. We can not say when we would get to any particular request.
[2025-10-30 18:43:55]
Shink22 - Posts: 21
Sounds great I hope to see it soon as it’s something I’ve always wanted in a platform. Thank you for all your help!
