Date/Time: Wed, 25 Nov 2026 16:39:23 +0000
Daily Chart Trendline Issue On Lower Timeframe chart
View Count: 399
[2025-10-28 21:21:52]
User688525 - Posts: 403
Hello Sierra,
If I draw a trendline on a daily chart (Historical Chart) going back several years and load the same number of days on a lower timeframe (Intraday Chart) so that the point of origin is visible on the lower timeframe chart, the trendline is slightly off on the lower timeframe chart.
For example, if the ticker intersects the trendline on the daily chart, the same trendline on the intraday chart is either slightly above or below the point of intersection which results in the ticker not intersecting the trendline on the lower timeframe when in fact it has on the higher timeframe?
Is there a setting I need to change or something I have overlooked?
Thank you
[2025-10-28 21:45:39]
Refer to the following:
Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar
Historical Chart Prices
[2025-10-28 22:00:11]
Thank you John. I searched the documentation before posting but didn't find this one.
Cheers
