Date/Time: Wed, 25 Nov 2026 20:52:12 +0000
Number Bars bottom always green
View Count: 437
| [2025-10-28 18:51:14] |
| User512353 - Posts: 198 |
SC2803 Study: Number Bars Column 3 Number Bars Text: No Text Column 3 Background Type: Ask Bid Difference Profile Column 3 Background Coloring Method: Based on AskVol BidVol Diagonal Difference Percentage of Bar Range Column 3 Text Coloring Method: Based On AskVol/BidVol Percentage With this settings, the bottom line bar in column 3 is always a green bar!?!? This does not look correct to me. |
| [2025-10-28 19:47:59] |
| John - SC Support - Posts: 48658 |
Refer to the following: Numbers Bars: Background Coloring Based on AskVol BidVol Diagonal Difference Percentage of Bar Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-05 12:33:48] |
Regardless of what is written in the linked webpage: Either the documentation is wrong, or the implementation is wrong, or - if the implementation matches the documentation and no bug is present - the whole concept is wrong. It is obvious that the bottom bar being always green cannot be correct. |
| [2025-11-05 15:19:50] |
Please get us your chart so we can see exactly how you have this setup and take a look. We do see what you are saying, but we need to look deeper and there are particular settings that can affect this, so we need to see how you have it setup. Folllow these instructions to get us your chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
