Date/Time: Wed, 25 Nov 2026 16:39:24 +0000
Numbers bars
View Count: 423
| [2025-10-28 18:03:36] |
| Kenyanking - Posts: 1 |
Hello sir, how do I compress XAUUSD numbers bars to fit my computer screen, the charts are huge with huge values.... please help me on that.... thanks
| [2025-10-28 18:03:40] |
Start by reviewing the information here: Numbers Bars: Scaling a Numbers Bars Chart You can also change the Bar Period to something smaller (say 30 seconds, instead of 1 minute) in order to break the bars up into smaller pieces. And you can aggregate price data together to have fewer price levels. Refer to the following for this: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Keep in mind that the Numbers Bars data is dense, and so there is a tradeoff between the data and what you can actually view on the screen. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
