Date/Time: Wed, 25 Nov 2026 16:39:11 +0000
how to Draw Developing Bar High/Low Lines
View Count: 445
| [2025-10-28 14:05:47] |
| RK123 - Posts: 11 |
Hello, I want to be able to see horizontal lines for the developing/current candle such that lowest & highest price for that candle draws lines to corresponding price being shown on the right most side (y-axis). I'm looking to see these lines for developing/current candle ONLY. How to configure this?
| [2025-10-28 15:38:51] |
If we are understanding this correctly, then use the "Highest High / Lowest Low over N Bars" study and set the "Length" input to "1". Then set the "Draw Style" for both subgraphs to be "Line at Last Bar to Edge". Refer to the following: Highest High/Lowest Low Over N Bars Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
