Date/Time: Wed, 25 Nov 2026 16:39:16 +0000
Currency Value Per Tick - Value Default
View Count: 443
| [2025-10-28 13:08:32] |
| mlurski - Posts: 7 |
I have a chart where I am displaying ESZ25_FUT_CME, but executing trades in MESZ25_FUT_CME. On the Chart Settings/Symbol menu the Currency Value Per Tick value returns to 12.5 upon opening the chartbook. Is there a way to permanently save the change to 1.25? |
| [2025-10-28 14:10:08] |
| Sierra_Chart Engineering - Posts: 25481 |
We do not know why it is changing in your case. There must be some reason. May be related to using the Chart Linking options. We recommend disabling all of the Chart linking options within the Chart Settings window for the chart. Refer to: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
