Date/Time: Fri, 10 May 2024 05:15:26 +0000
[User Discussion] - Average Daily Noise (ADN) Indicator
View Count: 3071
[2014-10-14 16:38:18] |
User121729 - Posts: 37 |
I would like some help on how to create an indicator that would do the following: Calculate Daily Noise which is smallest of the below 2 calculations: 1. Abs(Prev Day pit session Hi - Previous Day open) 2. Abs(Prev Day pit session Lo- Previous Day open) Calculate the average over n days of Daily noise as input by the trader. The is the AVerage Daily Noise(ADN) Add the ADN to the current day open and draw a line. This is ADN Hi Subtract ADN from the current day open and draw a line. This is ADN Lo. This indicator would be plotted on any intraday chart. Can I get some help on this? Thanks |
[2014-10-14 17:46:06] |
ganz - Posts: 1048 |
AC96172 It was done already https://www.bigmiketrading.com/elite-circle/33107-want-your-sierra-chart-indicator-created-free-2.html |
[2014-10-14 21:02:46] |
That one does not work properly.
[2014-10-14 22:40:13] |
JohnL - Posts: 27 |
You don't really need to do any programming for this. Just do the calculations on a daily chart and reference it from your intraday chart as I've shown in the attached chartbook. Set the number of days to average in the simple moving average study. |
ES-201412-GLOBEX [M] 5 Min #2 41926.939.png / V - Attached On 2014-10-14 22:37:56 UTC - Size: 83.2 KB - 730 views ADN.cht - Attached On 2014-10-14 22:38:11 UTC - Size: 141.42 KB - 502 views |
[2014-10-14 23:41:12] |
AC96172 That one does not work properly.
what does this mean exactly? |
[2014-10-15 01:48:26] |
Cannot get it to draw 2 lines on chart as a study overlay..
[2014-10-15 08:53:48] |
AC96172 The study works as expected using the given equation http://s28.postimg.org/qelj7smdp/dn2.png |
[2014-10-15 12:59:10] |
Got it! Thanks
[2014-10-16 05:04:34] |
Willson - Posts: 176 |
I am wanting this indicator also. I am not finding a way to load it into SC. Where to get? Where to put file? How to activate? Thanks in advance Regards |
