Date/Time: Mon, 29 Apr 2024 01:21:13 +0000
Line Draw Style on RTH Chart
View Count: 876
[2014-10-14 15:31:34] |
User56866 - Posts: 28 |
Hi When using the Line Draw Style for a study on a RTH chart the line is drawn across the gap between the two days, is it possible for the line to end at the end of the RTH session and begin again in the next session. IE. Do not draw a continuous line from one session to the other, I see this is already how the Point and Dash styles behave, can we do this for Lines also? Thanks, Ben |
[2014-10-14 16:13:08] |
User30668 - Posts: 108 |
User56866, Try setting the Draw Style to "Dash" instead of "Line" and select "Line Style" to "Solid". I hope that helps. Date Time Of Last Edit: 2014-10-14 16:16:53
[2014-10-14 16:26:30] |
Sorry, I guess I misunderstood your question. The way I found to do that was creating a chart with session times set only to RTH and aplied to it the Daily OHLC Study. Then I used the Study Price Overlay to have it overlayed on my main charts. I hope that is what you need. |
[2014-10-15 03:59:57] |
This is how the Line Draw Style is. You have to use another one that is not continuous. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
