Date/Time: Wed, 25 Nov 2026 16:39:23 +0000
ds40 Override Not Routing from Australia—Private IP(10.10.20.161) in Heartbeat
View Count: 389
[2025-10-23 07:15:57]
User921670 - Posts: 2
I'm trying to optimize Denali real-time latency from Australia by routing to ds40.sierracharts.com (NZ server) via override or auto-select, as my pings show it's much faster (45ms vs. 221ms to US servers).
However, heartbeats keep showing a private Source IP (now 10.10.20.161), suggesting NAT masking or routing fallback—transmission delay is stable at 20ms, but I want the full ds40 benefits for smoother spikes.
Settings:
- CME Exchange Data Feed Server Address and Port Override: ds40.sierracharts.com:443
- Always Use Port 443 For Real-time Data: Yes
- Allow Support for Sierra Chart Data Feeds: Yes
- Use Internal LAN IP for CME Data and Order Routing: No
- Real-Time Data Compression: High
- Remote Buffer Delay Send Time: 20ms
Pings (CMD, 10x):
- ds40.sierracharts.com: Avg 45ms (Min 43ms, Max 51ms, 0% loss, TTL 47)
- ds28.sierracharts.com: Avg 221ms (Min 219ms, Max 225ms, 0% loss, TTL 48)
Latest Heartbeat Logs:
2025-10-23 16:59:12.215 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=16, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=48, ActualMessageDelay=1.1 seconds, DataCompRatio=2.72, UncompressedBytes=85275, CompressionTime=0.001866(secs), NumCompressions=186, Source=10.10.20.161, MaxSendBufferSize=5443, MaxSendBufferSizeDateTime=2025-10-23 06:59:01
Thanks!
[2025-10-23 13:41:45]
Sierra_Chart Engineering - Posts: 25481
This is normal to see this LAN IP address:
Source=10.10.20.161
It is not a problem.
However, that IP address is associated with a server in the United States. That heartbeat is not for the server in NZ.
Date Time Of Last Edit: 2025-10-23 13:42:40
