Date/Time: Wed, 25 Nov 2026 16:24:57 +0000
Market Internal Data
View Count: 473
| [2025-10-21 04:49:09] |
| User873664 - Posts: 18 |
Hello, Does sierra chart support market internals data like for example NDOH (Nasdaq Stocks above 100 day average)? I was able to find this page Sierra Chart Market Statistics but was hoping there was some additional internals supported. Thank you! |
| [2025-10-21 14:27:20] |
| Sierra_Chart Engineering - Posts: 25481 |
These Barchart symbols can also be used: http://datasrv.ddfplus.com/names/index.txt They can only be used when the Current Selected Service in Sierra Chart is set to "SC Data".: Global Settings >> Data/Trade Service Settings >> Main Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-21 14:44:36
| [2025-10-21 16:22:41] |
Refer to this page: Barchart Market Statistics Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-21 16:35:26] |
Thank you! I was able to get these working. It was working when I had data set to SC Data, and seemed to be working on Teton CME routing as well. However, I was not able to get this working through the Find Symbol dialog. I had to open a chart of SPY, and change the symbol to $NDOH then press enter. |
| [2025-10-21 16:41:40] |
You will not find these on the Find Symbol window. But you can open a chart by entering the symbol in the "Selected Symbol" field on the "Find Symbol" window and then selecting "Open Intraday Chart".
