Date/Time: Wed, 25 Nov 2026 16:25:01 +0000
Denali
View Count: 404
| [2025-10-20 13:59:30] |
| User914407 - Posts: 65 |
Bonjour, J'ai un compte chez STAGE5 et le package 11 de Sierra : est ce suffisant pour trader en réel ou me faut il en plus le flux Denali ? Merci |
| [2025-10-20 16:27:25] |
From Google Translate: Hello,
I have a STAGE5 account and Sierra package 11. Is this enough for real-time trading, or do I also need the Denali feed? Thank you. What order routing service are you setup to use with Stage 5? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-20 16:53:10] |
Teton Autre question : si je trade le CME avec une propfirm, ai-je besoin de DENALI ? |
| [2025-10-20 17:23:50] |
Since you are using Teton, you do need to get the data from our Denali Exchange Data Feed. There is no other data available when using Teton. Right now, you have the following exchange active: - CME with Market Depth for Non-Professional Trading Accounts If you just need this, then that is fine. If you need other exchanges for the CME Group, then you can add/change by following these instructions: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections -- From Google Translate: Another question: if I trade the CME with a propfirm, do I need DENALI?
You do not need Denali if you are trading with a Prop Firm where you are using Rithmic for your trade service. In this case, you could use the Rithmic data, although we do not recommend it - refer to the following: Rithmic Trading Platform Service: Rithmic Support Policy But, if you are already setup to get the data from our Denali Exchange Data Feed, then you can use this with the Rithmic connection as well. This is the default - to get the data from us if you have it active - you would have to explicitly change this to not get our data. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
