Date/Time: Wed, 25 Nov 2026 16:24:55 +0000
Equity Candlesticks Lag Behind Real-Time Price Updates
View Count: 737
| [2025-10-17 17:39:38] |
| lighe - Posts: 2 |
Hi SC, I’m noticing that for equities/ETFs, the price on the chart updates in real-time, but the candlestick/bar lags behind, unlike futures, where everything updates simultaneously. I have already tried enabling “Include Odd Lot Equity Trades.” Is there a way to make equity candlesticks update in real-time with every trade, like futures? |
| [2025-10-17 18:33:46] |
For one chart where you have this occur, what is "Chart >> Chart Settings >> Symbol >> Symbol" set to?
| [2025-10-17 18:53:50] |
| lighe - Posts: 2 |
For the charts where this occurs, it happens with any equity, including NVDA, TSLA, and even the SPY ETF. I’ve attached a video showing TSLA side-by-side with MES: you can see that TSLA candlesticks lag slightly, whereas MES moves fully synchronized with the price. For reference, I’m using the following data feeds: Equities: Denali Exchange Data Feed – US Equities Consolidated Tape Futures: Denali Data Feed |
| Attachment Deleted. |
| [2025-10-17 19:21:33] |
| Sierra_Chart Engineering - Posts: 25481 |
Most likely this does relate to Odd Lot trades. Check this setting: Data/Trade Service Settings: Process Known Odd Lot Equity Trades for DTC Services (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) You need to reconnect after enabling that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
