Date/Time: Tue, 09 Jun 2026 14:47:49 +0000
Does Sierra not support Options Data Feed for GDFL
View Count: 1685
| [2014-10-14 06:42:48] |
| User95370 - Posts: 28 |
Hi, I am a GDFL subscriber and trying to view Nifty Options Charts with SierraCharts. I asked today a Global data feeds limited Customer Rep. about options symbols for sierra and he said Sierra does not support Options Data. Is it true? Is there any plan to support options charting for GDFL anytime soon?
| [2014-10-16 14:16:21] |
No Reply?
| [2014-10-16 15:56:01] |
We apologize for this. Options are supported when using Global Data Feeds but you will not see them listed in File >> Find Symbol. You need to manually enter them when you select File >> Find Symbol. Here are the detailed instructions for this: http://www.sierrachart.com/index.php?page=doc/GlobalDataFeeds_India.php#UsingOptionSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
