Date/Time: Wed, 25 Nov 2026 16:15:16 +0000
Full Documentation for All Subgraphs in “Numbers Bars Calculated Values” Study
View Count: 8879
[2025-10-10 13:08:48]
User249765 - Posts: 1
Hello Sierra Chart Support,
I’m requesting the complete documentation for all subgraphs included in the study “Numbers Bars Calculated Values”.
At the moment, only a few of them are described on the Numbers Bars documentation page, while the study itself includes over 55 subgraphs (SG1–SG55).
To better understand and use these values for analysis, alerts, and custom studies, I would like to know the exact definition and formula of each subgraph.
Here is the full list extracted directly from the study settings in my platform (build [insert your build number]):
SG1 - Ask Volume Bid Volume Difference
SG2 - Ask Volume Bid Volume Total
SG3 - Ask Volume Bid Volume Difference Change
SG4 - Positive Delta Sum
SG5 - Negative Delta Sum
SG6 - Ask Volume Total
SG7 - Bid Volume Total
SG8 - Maximum Ask Volume Bid Volume Difference
SG9 - Minimum Ask Volume Bid Volume Difference
SG10 - Cumulative Sum Of Ask Volume Bid Volume Difference - Day
SG11 - Ask Volume Bid Volume Difference Percent
SG12 - Number of Trades
SG13 - Total Volume
SG14 - Total Volume Bar Difference
SG15 - Average Volume Per Trade
SG16 - Average Volume Per Price
SG17 - Ask Volume Percent
SG18 - Bid Volume Percent
SG19 - Cumulative Sum Of Ask Volume Bid Volume Difference - All
SG20 - Point Of Control Volume
SG21 - Cumulative Delta Volume High
SG22 - Cumulative Delta Volume Low
SG23 - Ask Bid Difference To Max/Min
SG24 - Ask Ticks Bid Ticks Difference
SG25 - Cumulative Sum Of Ask Ticks Bid Ticks Difference - Day
SG26 - Cumulative Delta Trades High
SG27 - Cumulative Delta Trades Low
SG28 - Maximum Ask Bid Vol Diff to Closing Ask Bid Vol Diff
SG29 - Minimum Ask Bid Vol Diff to Closing Ask Bid Vol Diff
SG30 - Bar Duration
SG31 - Daily Range
SG33 - Weekly Range
SG34 - Finish AskVol BidVol Diff
SG35 - Finish AskVol BidVol Diff %
SG36 - Volume / Sec
SG37 - High Pullback Ask/Bid Vol Diff
SG38 - Low Pullback Ask/Bid Vol Diff
SG39 - Cumulative Delta Minus Delta
SG40 - Cumulative Volume - Day
SG41 - High-Low Range
SG42 - Point Of Control Value
SG43 - Diagonal Positive Delta Sum
SG44 - Diagonal Negative Delta Sum
SG45 - Low Bid Volume Percent
SG46 - High Ask Volume Percent
SG47 - Cumulative Delta Up/Down Tick Volume
SG48 - Total Up Tick Volume
SG49 - Total Down Tick Volume
SG50 - Up Down Tick Volume Difference
SG51 - Average Bid Trade Size
SG52 - Average Ask Trade Size
SG53 - Bid Volume Per Second
SG54 - Ask Volume Per Second
SG55 - Grid Lines
Could you please:
Confirm the definition or calculation formula for each subgraph.
Indicate whether any of these are deprecated, internal-only, or reserved for specific data feed configurations.
Clarify if this list represents the complete and current set of values for the study in the latest release.
This clarification would be extremely helpful not only for me but also for other users who use these subgraphs for data analysis and custom indicator development.
Thank you for your time and technical assistance.
Best regards,
Michel Bolognesi
[2025-10-10 13:43:28]
User431178 - Posts: 910
All are documented
Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions
