Date/Time: Wed, 25 Nov 2026 16:15:20 +0000
Multiple symbols displayed at the same time
View Count: 507
[2025-10-10 13:08:28]
User110225 - Posts: 29
Hello. Thank you in advance for your help.
I am trying to work out how to display multiple chartbooks for different symbols at the same time.
I look at 4 different symbols throughout the day. The way I do this now is to have each chartbook open and then click on the symbol that I want displayed. Each chartbook has 4 charts associated with it.
I have 4 screens, I would like, if possible, to have each screen dedicated to a particular symbol with all 4 charts on display on the screen. This way I can watch all 4 symbols at any given time. i.e top left screen - gold, top right screen sp500, bottom left screen gbp/usd and bottom right screen crude oil.
This will prevent me from having to keep selecting each chart every time I want to see an update, as currently I can only see 1 symbol at a time.
Thanks you very much and have a great weekend
Chris
[2025-10-10 15:52:50]
The easiest way to do this is to use Sub-Instances, and then have each sub-instance dedicated to the particular symbol and location. Refer to the following:
File Menu: New Instance (File)
