Date/Time: Tue, 03 Nov 2026 17:43:56 +0000
Request to Enable NQZ Delayed Data on Trial
View Count: 375
| [2025-10-08 21:12:55] |
| User518160 - Posts: 1 |
Hello Sierra Support, I am currently on the trial, when I try to open the E-mini Nasdaq on CME, the chart stays blank. Could you please enable delayed data for NQZ (Nasdaq E-mini) on my account, so I can test it during my trial? Thank you very much, Haidar Saleh |
| [2025-10-08 21:31:35] |
| John - SC Support - Posts: 48408 |
While on a trial you have limited data that you have access to. Refer to the following: Sierra Chart Trial Account If you want data for symbols other than that is available during a trial, then you would need to change to one of the paid packages. Follow the instructions at the following link for this: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
