Date/Time: Wed, 25 Nov 2026 21:06:23 +0000
Edit alerts
View Count: 561
[2025-10-08 18:34:26]
User472677 - Posts: 400
I set alerts from the quote board. A window pops up when an alert is triggered. To change the alert I go to Edit on the window. I click on Edit, nothing happens. However do I fix it?
Is there one place where I can see all the alerts I have manually set. Alert Manager is not helpful because I have a large number of studies based on automatic alerts. Alert Manager shows everything and it is not practical to find alerts I have manually set.
[2025-10-08 19:43:25]
John - SC Support - Posts: 48659
We see that the option for "Edit >> Edit Alert" on the Alert Pop-Up window does not function. We will look into this.
As to the Alerts that you enter on the Quote Board, these are "Symbol Alerts". You can view all of the entered "Symbol Alerts" on the "Window >> Alert Manager" by selecting the tab for "Symbol Alerts". You can then manage/modify them there.
If you are wanting to know where ALL alerts that have been set reside, then this does not exist. There is not a way to know if an alert has been set on a study, for instance, unless that alert actually goes true and then is listed in the Alerts Manager. Otherwise, you would just have to know where they are.
[2025-10-08 20:17:51]
Thank you.Being able to edit alerts on pop up is very important to my trading. I will appreciate a quick solution. When will the fix be done?
[2025-10-08 21:25:29]
We have passed this along to Engineering to look into. We do not know how long it will take for them to look it over and figure out what to do.
[2025-10-09 22:01:09]
We are looking into this.
[2025-10-10 05:09:38]
We could not find any problems with this. You first need to select an alert line in the Alert Pop-up window.
And then it must be a Symbol or Time alert to be able to edit it. No other type of alert can be edited.
[2025-10-17 00:21:29]
I do exactly what you said. I have been a long time user of sc and using this feature for a long time. It is only recently that it has stopped working reliably. Sometimes it works, other times it dies not work. I have tried but have not been able to pin it down why it is unreliable now after working well for years.
[2025-10-17 05:37:43]
Update Sierra Chart to the latest release, and then that has logging in the Window >> Message Log, if an alert cannot be edited.
Instructions:
[2025-10-25 00:14:31]
I sent you logs. Have you found a fix?
[2025-10-28 15:32:13]
We did some additional testing, and identified another issue, which we are resolving.
This will be out in the next release.
[2025-11-12 18:54:35]
I just want to follow up. Have you fixed the alert edit issue?
[2025-11-12 18:56:15]
[2025-11-12 19:37:53]
This was all resolved at the end of October, so the current release has this fixed.
Keep in mind, the main issue originally, was that the specific line in the Alert Pop-Up needs to be selected first, then selecting "Edit >> Edit Alert" will actually edit the particular alert.
If you select an entry that is not a "Symbol" or "Time" alert, and try to edit it, you will get a message in the "Message Log" stating this.
