Date/Time: Thu, 02 May 2024 22:45:43 +0000
Replay doesn't work?
View Count: 1291
[2014-10-13 21:38:47] |
JingIt - Posts: 44 |
I follow the instruction to use replay feature but seem like it doesn't work, I have tried with different time period back, un check and check skip empty periods or trying another reply mode. The chart still show the latest updated and doesn't replay. Any idea to fix it? |
[2014-10-13 21:51:46] |
Did you scroll the chart back before starting the replay?
[2014-10-14 08:21:56] |
Scroll the chart back before start the replay works!!! Awesome, thank you. Great support, I become love Sierrachart now!!
