Date/Time: Wed, 25 Nov 2026 16:15:17 +0000
Chart Value Window
View Count: 482
[2025-10-07 06:54:40]
nicktrader - Posts: 817
Is it possible to disable regions 2+3 in the Chart Values Window so that they are no longer displayed?
I deliberately do not display any values in these regions (see pic).
Many thanks
imageChart Values.png / V - Attached On 2025-10-07 06:53:38 UTC - Size: 18.54 KB - 203 views
[2025-10-07 14:30:15]
There is no option to not display the other regions when using the Chart Values Window.
Our recommendation would be to use the "Compact Chart Values Window" which does have an option to only display the data for Region 1. Refer to the following:
Chart Drawing Tools: Compact Tool Values Window Shows Chart Region 1 Values Only (Tool Settings >> Chart Values >> Chart Values)
