Date/Time: Wed, 25 Nov 2026 22:26:08 +0000
SierraChart on Debian Linux - is 32-bit architecture needed in Wine?
View Count: 1524
[2025-10-06 09:21:59]
User821223 - Posts: 28
Hello, I have a question related to running SierraChart on Wine in Debian 13 Linux.
I installed Wine by just running a command “apt install wine”, I did not add 32-bit architecture and so far, SC is running smoothly.
Do I need to add 32-bit architecture to run SC without issues? Is SC using some 32 code / libraries that would require 32-bit architecture to be added?
Cheers,
Przemek
[2025-10-06 13:57:56]
Tony - Posts: 738
I think Sierra stopped support 32-bit since version 2177, around Oct. 2019
[2025-10-06 14:10:23]
Yes, I've read about it that they don't provide 32-bit installer anymore since quite some time, but sometimes, there are some libraries / parts of code that are left as 32-bit and I'm curious whether that is the case.
I assume that if there is only 64-bit installer, everything should work without adding 32-bit architecture in Wine.
I'd appreciate feedback from developers whether my assumption is correct ;-)
Cheers,
Przemek
[2025-10-06 16:38:50]
There are no parts of Sierra Chart that are 32-bit. Everything is 64-bit and has been for quite some time now.
[2025-10-06 18:01:06]
Awesome! Thank you John! It confirms that I don't need to add 32-bit architecture in Wine ;-)
Cheers,
Przemek
[2025-10-07 13:49:06]
Sierra_Chart Engineering - Posts: 25484
No you do not. It is not possible to mix 32-bit and 64-bit modules. Sierra Chart is entirely 64-bit.
[2026-01-20 13:21:20]
Hi, one more question - does it make any difference which Windows version I choose in wine? Will 7 be better than 10?
I just noticed the sentence "Newer versions of Windows, in particular windows 8 and 10 and 11, are absolutely completely deranged and lunatic." in this thread: Videos and started to wondering if it makes any difference.
Cheers,
Przemek
[2026-01-20 14:32:44]
It might make a difference . You just have to try and experiment. We do not know the answer to this.
[2026-01-20 14:38:41]
Tony - Posts: 738
@User821223,
I chose Win 10, works great
[2026-01-21 11:02:27]
Thanks for the answers. I also have Windows 10 selected and it works great so far. I don't want to play changing it to Windows 7 because I don't want to break what I have now. I will survive with the uncertainty if that's not a known answer;-)
Cheers,
Przemek
